Thank you for your post, greg aguilar!
Both error codes "E10" and "E11" stand for fill time is too long on your Frigidaire washer. This could be an issue with the water pressure coming into your washer the psi must be above 30 psi. If it is not you may need to correct the pressure issue. If it is check to assure that the hose is not kinked or blocked. You may need to replace the water inlet valve, pressure sensor, or control panel. I would recommend having a professional technician come out to provide a proper diagnosis for repair. Hope this information is helpful to some degree. -Matt
SOURCE: My Frigidaire washer is reading error code
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
SOURCE: e10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
SOURCE: e10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
SOURCE: FAFW3577KWO washer-code E11
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
