Nothing cause i dont want to make anything worse
SOURCE: Westinghouse SK32H240S TV will not show picture...
Some solutions to this same problem were posted here, hope this helps.
SOURCE: Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue. I bought mine at Best Buy in '06 and was told today that they will test the power supply for free. It may range from $50.00 to $100.00 depending on where you can get it. This does not include labor for those not qualified to work with electronics. Hope this helps you.
SOURCE: Westinghouse tv ltv46w1hd sound no picture
www.cfusion.com has the spare parts for that tv. it sounds like it is the mainboard. shouldn't be more than 150-200 to replace.
SOURCE: TV goes black
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
SOURCE: TURN ON TV, SHOWS PICTURE FOR A SECOND, THEN THE
there is a bad capacitor in the power board
The Can shaped little device will have a domed or puffed up top on it the value is printed on the side you can , or have someone replace the cap and you should be all set
