I only been able to to check the pins in the ends of the hdmi cable and the back of the ps4 but they look fine. I was going to try a different better hdmi cable and different port on the tv.
SOURCE: Uncharted: Drakes Fortune freeze
Deleting the game data and reinstalling via the disk after installing the new firmware update seems to allow play to continue, when nothing else does. Although after about 45 minutes I had a 2nd hardlock and had to delete and reinstall again. I think played for another hour with no issues.
SOURCE: exactley the same
Firmware 3.0 has been causing problems for Uncharted. Go to [Settings] and download the firmware 3.01 to fix the issue. The update is optional so you may not have known about it.
SOURCE: my ps3 doesnt work
If you turn off the PS3 and then hold the power button down for 10 seconds, you will hear two beeps and the PS3 will turn off again. If you now turn it on, the display settings should have been reset.
SOURCE: My PS3 has stopped playing voice overs.. / commentary on FIFA 09
When powering on ps3 hold the power on button until it beeps. then it will ask you a series of questions. I answered yes to each question and it solved the problem. Fwiw, I had this problem with not only blu ray but also regular dvds.
