Codemasters Brian Lara International Cricket 2007 for Windows Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change the resolution of the game
I have got the game stuck on a small screen i have to change the resolution of my comp to try to make it full screen but it doesn't quite fit help.
Anonymous
Level 2:
Sniper:
  • Expert 50 Answers
  • Posted on Jul 06, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
50
Questions
Helped
30502
Points
168
First you can change the resolution of the game. Mostly it's options - video - resolution. You can know the resolution of your computer to click right mouse button (in windows) - properties - resolution. One of these resolutions can you use in your game.
I hope this can help you. Not working, just ask me again.
My game is too small to play
What game? if it is an older game, you might need to lower your screen resolution to play it.
  • Resolution - Try to adjust the resolution, for guidelines please check out this article : How to adjust your Screen Resolution / Size or this one if the game has been downloaded: How can I change my screen resolution?
I am trying to play the game on my comp. But the display does not use the entire screen. Is there a way to adjust the size?
Modern Games need Wide Screen Monitors.
If you are playing old games on a wide-sreeen monitor, temporarily set the monitor resolution to 1024x768 or 1280x1024.
I have a toshiba and i want to play a comouter game and each time i press up or down it movws my screen not my game
set to correct resolution the screen of your comp.. then read the resolution required of your game and the help keys to operate your game.
When the game enters the direct show and begins the screen is centred in a small box about 1/4 the size of my monitor. The game will not go into full screen. Is this normal? My PC is a pentium 4.
Yes, it is normal. This is a very old game and came out before our 1080p resolutions, making the output naturally very small. Quickest fix is before you play it, right click the desktop and go to properties/personalize then go to display then adjust resolution on vista or win7 (or the resolution tab on xp). Change the number selected to one closer to 800x600 and start the game. Note: this will make everything BIG. When done just change it back with these same steps.
Small screen when opening games in windows 7 64 bit . have updated drivers and changed screen resolution - nothing helps, and its all games thats not fullscreen. System is a Aspire 4738ZG 14 inch...
If you were to reduce the screen resolution to the recomended for the game, it should fill the screen depending on what aspect ratio the game is. The higher the resolution the smaller the picture.
Hope that helps.
2helpful
I have an hp mini and i want to play games on it but the picture wont fit the screen is to small. how do i fix it to fit into this size
Try changing the Game Resolution from the Game Setting Menu or try changing/adjusting the Screen Resolution of the Computer according to the Game resolution setting.
Good Luck!!!!!!!!!!
Sudden change to screen resolution on Spidaire Solitaire only
hi
sheiab try this
go to run and in run type msconfig and in msconfig try to change the boot oder of the computer and disable all start up from the computer and check the things would will definetly work
1helpful
2answers
Toshiba Satellite 17" L355-S7812 Gaming Resolution Problem
This is a common problem with Toshiba Notebooks. Their driver is locked onto Intel version 13.29 which is a buggy driver that has an issue keeping the aspect ratio settings in the control panel. You will want to download Intel's 15.9 drivers (the zip file for developers) and force that driver to install on the notebook by manually installing the driver in the device manager.
Another fix is to enable hot keys in the intel graphics control panel and press control , shift , f11 when the game starts to change the aspect ratios of the screen.
Its annoying yes and I wish i would have known about this myself before purchasing a toshiba sattlelite.
Screen problem
Go step by step: 1. maybe you are trying to set a higher resolution then the screen can be 2. its possible that your comp don?t recognize the screen right, check the "display properties" make sure it?s the right model 3. reinstall the drivers. Restart. 4. if its not the software it?s the hardware, try connecting the screen to another computer if it works fine the problem is in the display board . Good luck
Top Codemasters Video Game Consoles & Games Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Alex
Alex
Are you a Codemasters Video Game Console and Game Expert? Answer questions, earn points and help others
