Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
Posted on Dec 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sony Bravia 52W4100 comes on for about 10 seconds, then on its own switches to the stand by mode. The picture and sound go off and the standby light flashes. It stays this way until I unplug it then the same problem repeats. No buttons on the TV or the remote have any effect. The TV is about 7 months old.
Larry
Level 3:
  • Sony Master 5,042 Answers
  • Posted on Dec 30, 2017
Larry
Sony Master
Level 3:
Answers
5042
Questions
Helped
1241742
Points
18413
Test the power supply voltages after it shuts itself off, mainly the PSON voltage as that will determine if its a main board issue or power board
5 Related Answers
Anonymous
  • 320 Answers
  • Posted on Nov 10, 2008
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Anonymous
  • Posted on Mar 24, 2009
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Anonymous
  • Posted on Jun 24, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Anonymous
  • 1077 Answers
  • Posted on Jun 29, 2009
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Anonymous
  • 197 Answers
  • Posted on Jul 02, 2009
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
2helpful
2answers
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
16helpful
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Sony Bravia 52" 1080p LCD Full Pixel Mode Screen Problem
HI NORMALY WE ADJUST THE PICTURE THROUGH SIZE PLEASE GO TO PICTURE SIZE ADJUSTMENT AND ADJUST THE SIZE
THANKS
MUHAMMAD NASIR
Pulsing/skipping picture on Sony Bravia 52'' LCD flat screen TV.
Yes it sounds like a lemon. A firmware update is the next thing to try.
4helpful
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
