HiIn order to check quick, you might need extra battery. In your neighbor some who has multimeter you get help from them. Or your local repair shop could help you easily.
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
How old is your battery? You may want to think about buying a new one as it may be on it's way out. Even if it is fairly new you might have a lemon of a battery. It happens at times. IF your psp is new and your battery is doing this you should contact sony and see if they can replace your battery for free or a nominal charge.
