Televison & Video Logo
reaper Posted on Nov 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to PCB reset hitachi 42 " plasma tv i dont have the remote and the panel button lock is set on...so the panel buttons wont work.... Any way to fix it ?
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Nov 25, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003173
Points
237762
Without its remote control, you can't make a reset to this set. In fact; a hard reset procedure do not want a remote control, but,. if you wish to make a system reset [Factory Reset]; there is no other way without a remote control.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
To get more details about remote controls. visit these sites.
Remote Control Codes
Electrohelponline
4 Related Answers
Anonymous
  • 95 Answers
  • Posted on Mar 11, 2008
SOURCE: locked tv
What is the make and model number of your flat screen tv.
Anonymous
  • 3 Answers
  • Posted on Jun 08, 2008
SOURCE: Tedelex EC-PD2000 42" plasma TV
Yes, I had the same problem, it happened after 14 months of my purchase, or just 2 months after expiry date of warranty. But remember they have 60,000 hours warranty on screen and this fault is part of screen (no picture J it is screen problem), I called LG, first they did not accept the claim but soon after I mentioned that I have done many research and this is very common problem due to use of faulty part or unreliable design, and if they don't fix it on their cost I will take legal action, one of the supervisor contacted me and after saying LALALALALALALALALALA accepted to send someone to fix with no cost. But I have found out they did to many others whom take this mater serious so it was not just me alone J They are aware of using faulty part is some ranges of their products and now this common problem appears, LG don’t like it and wants to somehow get away. ((((((((((So don’t let it happen))))))))) some of us paid around $5000 to $7000 when this TV came out, recently price went down to around $2000. CALL THEM and ask FIX or COURT? For sure they fix it for you free of charge J Imagine how much would it cost them to recall all TVs which they know is faulty?
Enjoy
Anonymous
  • Posted on Dec 18, 2008
SOURCE: Panasonic TH-50PX60U no buttons working
The software in the cpu of this set is damaged you must reload it to fix the problem..
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Apr 26, 2009
SOURCE: remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
2helpful
2answers
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Dont have volume
could be mute button on remote,or check tv menu/audio/settings.it may be on audio out which sends it to separate amp.
2answers
Child lock is on
If there is a menu button on the tv itself, or on the remote your using press it and search through the menu, if it will let you, and find the reset factory settings, or something of that nature. Try that and see how it works out. Sorry i can't give anything excact, but i'm not familiar with LG products.
Akai 42 plasma controller can not be programed tried every code
i just had this same problem with my 42" akai plasma and after getting no help no where i finally figured it out on my own. The model i have is a PDP42Z5TA but my guess it will work with yours also.if your remote is like mine there should be a "set" button somewhere up at the the top.hold this down till the "tv" button goes solid red. with the tv on or off keep pressing the power button till the tv turns on or off( dont go too fast) or you can pass it up easily cause when the tv does turn on or off you have to hit enter to lock it in.
42HDS69-INPUTS
couple of ideas ... on the TV look for the button named input you can change it to the one you cave connected to there .. I am looking up the remote press the TV button then the menu button to move through the on screen input control
2answers
Hitachi 42plasm tv
take it back to the store, make sure the power cod is in all the way and you dont have it on a switched outlet, see if you can see any cracks or if the box was damaged/
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
