Faxes no longer print out legibly. Some lines are missing or partly printed. One or two lines printed ok inbetween.
Sounds like your print head is dirty if you are using a inkjet machine. Although you didn't say what machine. Your machine should perform a print head cleaning procedure if you turn the machine off and then on again. Otherwise you'll need to replace the print head which may or may not be part of the ink cartridge depending upon the machine in question - good luck
The
fax element of the Printer contains a memory feature for storing
faxes in the event of a printing problem. This feature is useful for
protecting yourself against missing faxes if your printer runs out of
paper. In order to retrieve missed faxes, the feature must be
switched on when the faxes arrive. You can reprint faxes stored in
the device's memory from the main control panel. You should allow
approximately 5 minutes for this task, or longer if many faxes are
stored in the memory.
Instructions:
Load paper in the input
tray.
Press
the "Setup" button on the front of the printer.
Select
"Tools," then "Reprint Faxes From Memory."
Press
"Cancel" to stop printing. Faxes are printed in reverse
order; the most recent fax is the last to print.
