10-30-12
Cost calculations for recirculation system vary widely.
These systems cost more, and they cause higher operation cost of water heater.
1) When pump is OFF, then hot water is no longer leaving the tank.
Most recirculation systems have choice of timer for setting specific times of operation, or thermostatic operation that activates pump when sensor detects temperature less than 90 degrees
BUT...
2) Condition of plumbing is suspect here because you are not receiving fully 90 degree hot water from the recirculation system.?.
Bad single-handle faucet cartridge, or bad recirculation check valve, are causes of crossover. Clean recirculation check valve with white vinegar. Replace worn faucet cartridge.
Test for crossover.
http://waterheatertimer.org/Crossover.html3) There are other suspects, such as water leak.
Drips, broken pipe, bad TP valve.
Turn off all taps and put ear against pipe to listen for running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen4) High costs: Lifting single-handle faucet in middle will immediately cause cold water to enter tank. Even if no hot arrives at tap, because the cartridge is drawing both hot and cold in equal amounts when handle is lifted in middle.
Today it is more efficient to install dual-handle faucets so tank is not receiving constant dose of cold water when single-handle faucet is not used correctly or tediously.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
