My monitor screen suddenly got upside down.Every attempt to fix has been failed. I am using it now putting upside down which is very painstaking. Is it Windows XP issue or monitor issue, please help!
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Testimonial: "great! I am convinced of the phrase "knowledge is power" now."
SOURCE: OOPS! How to invert screen image )get it back where it belongs)
just take it to the showroom where u got it from. this problem can be fixed without any big problems
SOURCE: upside screen
this may just work:
on your keyboard, press: Ctrl and Alt then the UP arrow at the same time.
SOURCE: monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
SOURCE: my monitor is upside down. seriously, this is not
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key.
