Unplugging from mains, unplugging the dvd player and gaming device holding down the power button for 30 seconds
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Testimonial: "Thankyou, your advice was helpful."
Hi, thankyou, it won't respond to anything but has a constant blinking without any pauses , does this probably mean the main board is faulty and if so can it be repaired or should I return it to where I bought it.
75% might be. It will be best to make it confirm. Contact any service tech: and seek his advice too. Sometimes, if there is any loose contact with any cable connections with its socket, this kind of fault can occur. Anyway, I don't think so. But isn't it will be a best practice too; to contact any before make any further repair? I might be far away from you, and I had the details that you've provided here, and with it I did posted a solution. OK?
SOURCE: Won't turn on now
ftry to unplug it and push the on/off switch...plug it back in and see if it will turn on
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to [email protected]
SOURCE: My TV will not turn on....it's red light just blinks
The main board or the power supply is seeing a start-up problem.
When there is a start-up problem discovered the TV will flash the red light and the TV will not be allowed to power up.
A TV service tech will have to check out all the different boards to find what the problem is. Sorry, there is not an easy fix for you issue.
I hope this information has helped you.
Good Luck.
SOURCE: lg 50pq3000-za plasma tv will not switch on from
power problem possible fried power capacitors
possible cause power surge could occur if unplug while tv on
must change 6 power capacitors
these original capacitors are on the low end minimal ratings
1-2 hours in house labor, cost est $200 plus minus
