Do a hard reset : CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone. So, backup all of your data in phone memory. Enter *#7370# from standby screen and the standard code for nokia phone is 12345. After that, backup all data in memory card to PC. And then format your memory card. Good luck.....
Hi, Don't worry this caused because of two reasons 1)flipdown application might be corrupted or 2)You would have installed some virus in the name of flipdown .
Due to these two reason the phone is behaving like this
First try this: 1)Click the MENU button continuously now you can see the application running behind the screen.select all the application and close it.and go to menu->application->application manager delete the flipdown application.
2)Your not even able to do any thing you have to reset the phone Hard reset code is type *#7370# default code is 12345 unless your network provider has changed.If it is changed you have to call him and ask him about the code.
Note:If your phone is not willing to start up.you can try this.: Press these buttons simultaneously for hard reset. on/off + * + 3
Please do rate the solution if the issue is resolved or post a comment for further assistance.
try a hard reset you will wipe the phone you can back up whatever you want to keep if you like
Hard reset. Turn off the phone. Press and hold three keys together, the green key, the '*' key and the number '3'.Then, turn on the phone and don't let the three keys before you see theNokia hands logo.
Check if your handheld supports multiple languates. Your product manual may contain information about changing languages. If it does not, you may wish to find out if your handheld supports multiple languages by performing a hard reset (be aware that you will erase all data from your device when you do a hard reset). On the startup screen after the hard reset, you may be asked to select a language. If you asked which language you want to use, select a language and install a localized Palm Desktop (below). If you're not asked, your device does not support multiple languages.
Well you will have to perform a Hard reset on the device to resolve this issue. Once the Hard reset is done you will get a prompt to select the language in the options.
Follow the below link to perform a Hard reset on the device.
