I have a beko wme8227b washing machine. it stopped spinning so i checked error code and it was f18, I reset it and it stopped again and then had error code f11, now when I check the error code it says 8360
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
SOURCE: Whirlpool washer model WFC7500VW1 came up with
that same thing is happening to me and i dont know what to do!!
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
SOURCE: how to reset or unlocked the beko washing machine timer
My washing machine time delay switch is flashing and I can't turn the machine on what do I need to do?
