I assume that you are looking for an e528 adapter. There are many adapters available on Amazon and eBay (search for "e528 charger"). If instead you are saying that the machine works fine when the charger is plugged in, but not when you are running off of the battery, then how do you know that your battery is OK?
SOURCE: I CAN'T FIND MY BLUTOOTH
If your sure you have it -you will find the settings in-Control Panel-- go to START>CONTROL PANEL
SOURCE: emachines e528 touchpad not working
Hello try to renew the driver from here:
https://support.gateway.com/us/en/emac/product/default.aspx?modelId=3234
Please unzip the file before you install.
Try uninstall the old one first
Or the touchpad have a fault.
You can buy a wireless mouse if you have no luck with the driver.
Good luck
Hi Nur Hossain, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Will it work while the charger is plugged in but shuts off when you unplug it?
