Question about Cover My Tractor Tractor Cab-Enclosure for Massey Ferguson 1540 with Folding ROPS - Black. Requires N2 Fiberglass Canopy Kit
What is the main bearing bolts torque.the connecting bearing bolts torque and cylinder head bolts totque for E3CD engine in 1540 massey ferguson tractor
    Scholar:
  • 71 Answers
I don't have your answer but if you google torque specs for your engine I'm sure you will find your answer. When I'm not sure I will call a dealer and they will most likely help out with the info
Posted on Dec 05, 2014
  • gregory kellman
    gregory kellman Dec 05, 2014
    did find spces on the net i found for the 1260 massey ferguson but crankshaft not same the tractor was by iseki for massey ferguson
  • gregory kellman
    made by iseki for massey ferguson
6ya staff
SOURCE:
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
Hi I need the torque settings for both the cylinder head and the bottom end bearings for a 1997 Toyota Prado (3.4litre petrol). Thanks
1997 Toyota Prado 5VZ-FE
Cylinder head bolts:
Tighten the cylinder head bolts in criss cross manner inside out, in four stages as under:
Stage 1. Torque the bolts up to 17 Nm.
Stage 2. 34 Nm.
Stage 3. Rotate all the bolts 90 degrees.
Stage 4. Finally rotate all the bolts further 90 degrees.
Main Bearings:
Tighten the main bearing bolts in two stages, as under:
Stage 1. 61 Nm.
Stage 2. Rotate the bolts further 90 degrees.
Big end bearings:
Tighten the big end bolt of connecting rods in two stages as under:
Stage 1. 25 Nm.
Feb 27, 2014 | Toyota Land Cruiser Cars & Trucks
Torque specification
petrol engine alloy head 65lbs
main bearing caps 80lbs
big end bolts 40lbs
Nov 21, 2013 | Cars & Trucks
How to torque engine heads,rod bearings and main bearing by foot pound?
cylinder head bolt torque for a DOHC Turbo 3.0L V6
92 ft lbs.
cylinder head bolt torque for a Non-Turbo
76-83 ft lbs.
main bearing caps
mark on head of bolt "9" 59 ft lbs.
mark on head of bolt "10" 70 ft lbs.
connecting rod nut 38 ft lbs.
Sep 07, 2010 | 1992 Mitsubishi 3000GT
Torque specs for 1.5 kia rio connecting rod
TORQUE SPECIFICATIONS kia rio
Cylinder Head Bolts:
(21.7ft.lb) or (3.0kgf.m) 90?
May 22, 2010 | 2001 Kia Rio
What is the right Torque Specification of the cylinder head bolt,main bearing and connecting rod bearing for a 1997 Ford F 150 4.2 liter? Thank you...
Cylinder heat bolt torque:
Torque sequence --------- front | 7 3 1 5 | | 8 4 2 6 | --------- Step 1: Torque all bolts in sequence to 14 Ft/Lbs Step 2: Torque all bolts in sequence to 29 Ft/Lbs Step 3: Torque all bolts in sequence to 36 Ft/Lbs Step 4: in the sequence, loosen the cylinder head bolts three turns. Step 5: Tighten short bolt to 15 - 32 Ft/Lbs Step 6: Tighten long bolt to 30 - 36 Ft/Lbs Step 7: Tighten all bolt to 175- 185 degree note: Do not loosen all of the cylinder head bolts at one time. Each cylinder head bolt must be loosened and the final tightening prior on the next bolt in the sequence.
Main bearing torque:
Torque sequence: Step 1: torque bolts to 91 Ft/Lbs with the exception of the rear main bearing cap Step 2: torque rear main bearing cap bolts to 88 Ft/Lbs Step 3: torque brace bolts to 40 Ft/Lbs
Connecting rod torque:
Torque sequence Step 1: Torque to 29 Ft/Lbs Step 2: Turn an additional 90 degrees
May 17, 2010 | 1997 Ford F150 Regular Cab
Cover My Tractor Tractor Cab-Enclosure for Massey Ferguson 1540 with Folding ROPS - Black. Requires N2 Fiberglass Canopy Kit Logo
887 people viewed this question
Top Cover My Tractor Garden Experts
roeb
john h
Marvin
Marvin
Are you a Cover My Tractor Garden Expert? Answer questions, earn points and help others
