Showing error 100-0001 in my copier
Code E100-0001 Description The BD signal is not detected 10 times or more within 10 msec in 5 msec after the generation of the laser drive signal Causes The wiring is faulty (short circuit, open circuit). The BD PCB is faulty. The laser scanner unit is faulty. The DC controller PCB is faulty. Remedy 1. BD PCB Try replacing the BD PCB. Is the problem corrected? YES: End. 2. Laser scanner unit, DC controller PCB Try replacing the laser scanner unit. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
