I think an LED problem is more likely. The LED strips are usually powered by a driver circuit on the power supply board. You can check this with a bright flashlight shining on the front of the display at about a 20° angle from parallel to the display. If you can see the picture or the menu with the flashlight beam during the "dark" period, the problem is NOT likely to be the T-Con board.
You can also look at the back of the set with the cover removed - most sets have a number of vent holes in the back plate through which the backlight can be seen when it is on. If these holes go dark when the TV goes black, the backlight is being turned off.
When the screen is lit, take a picture quickly and look for dark spots. Maybe one of the LEDs has a partial short that shuts down the LED power and triggers a retry cycle. If so, after a while it will burn out and then the entire LED strip will be inoperative.
Maegan,
You have already changed power supply/led board and main board. What is left now is the tcon and scaler board. Please try tcon.This may solve your problem. By the way, there is a systematic way of singling out the faulty board. A little research on this will save you save you time and money. Good luck.
Something else is going on. The T-Con board has no other function than controlling the picture. If there is a separate board for the led drivers, I'd suspect that one. The main board controls the sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
