Question about Pure Digital Flip Mino Digital Camera
Flip Mino HD will not boot, charge or reset
Day 1: Recorded 58 minutes of video in 5 minute segments. Battery ran down during last recording, camera shut off. Camera would not accept a charge, reported "temp too high" with thermometer on screen. After sitting several hours to cool, still would not accept charge. Found instructions on web to reset by holding power button 10 sec. Reset still did nothing. Set camera aside for 12 hours. Day 2: Camera accepts charge, offload Day 1 video and erase all video from camera. Shoot 50+ minutes of new video, again in 5 min segments. Camera again dies and shuts off. Will not accept charge, will not reset via holding power button. Use paperclip to press internal reset button. Still no luck. Pressing power button, "Low Battery" screen appears with backlight on. Camera shuts down several seconds later. Day 3: Purchase external charger accessory (Flip branded charger) to attempt to get camera to charge (won't accept charge from latpop/USB) Camera still will not accept charge.Now camera will not even boot, and screen is dark. No "Low Battery" indicator.. Day 4 - 7: One website says "let camera sit for several days and try again" Camera not touched for 3 days. Day 8: When connected to power source, screen occasionally turns on, low battery icon with lightning bolt and red meter appears. Camera then shuts off after several seconds.No luck so far attempting to get camera to accept charge.
Should I just return it for a refund and forget about the video?
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Posted on Aug 06, 2009
6ya staff
SOURCE:
I have a flip slide hd S1240W that has not been charged up in a long time. I have tried to charge it and attempted to reset and then charge. All that is happening is a red flashing light but nothing at...
Try removing the batteries, plugging into your computer, popping the batteries back in, and removing. Wait 5 minutes, and plug back in! This should have an affect!
Oct 06, 2013 | Flip Video SlideHD S1240W HDMI Camcorder
Tip
How to convert flip video (HD).mp4 to wmv for import movie maker ? Flip movie...
Flip movie files mostly recorded in mp4 file format, currently there are Flip Mino/Mino HD, Flip Ultra/Ultra HD and the latest released Flip Slide HD camera record.mp4, the awkwardness of Microsoft movie maker only takes WMV, AVI and MPG file, among them, WMV is the most popular one. And the first step to get flip video to windows movie maker is to convert/change flip video.mp4 to wmv.
Step by step on how to convert flip video (HD).mp4 to wmv for import movie maker.
Step 1.Download Flip Converter, install and running it.
Step 2.Click Add button to load Flip Video files that you want to convert
You can load many short clips at one time, batch load and batch convert features is available. You can simply load a video folder. Select WMV format in the Profile pull down list."
Step 3.Click Start Button to start conversion
That is it, with above 3 steps you can convert your flip video files to wmv.
Now, You will experience a new lifestyle. Just Free download and enjoy it.
on Sep 17, 2010 | Computers & Internet
My Flip Mino HD camera turns off while recording!
I had the same problem! But I turned it off, stuck a paper clip in the little hole inside the hole at the bottom for 10 seconds, then i held the power button for 5 seconds till it turned on and it works just fine now :)
Nov 18, 2012 | Flip Video Mino Camcorder
My flip mino HD has been charging for 3 hours and will not turn on. I've tried resetting the battery and it still won't turn on
Is it plugged in directly or with a USB extension cable? Some cheaper cables are not sufficient to charge it.
Mar 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Jan 26, 2010 | Pure Digital Flip Video Ultra Camcorder
Camera software corrupted??
I had the same problem with my flip mino HD. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Apr 13, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Mino won't turn on!
I had the same problem. Here are the steps I took to fix it.
Feb 03, 2009 | Pure Digital Flip Video Ultra Camcorder
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Zero space to record but no files on camera
MAC Users....
Remember those annoying "hidden files"...that's the problem.
Go to Utilities/ Disk Utility/ (select the Mino)/ Erase (up top)/ Erase (near the bottom)
and the problem will be resolved.....
Make it a great day
Dec 29, 2008 | Pure Digital Flip Mino Digital Camera
Flip Mino HD Screen Frozen
I had the same problem when it was brand new straight out of the box. Below is Pure Digital's (manufacturer of the Mino HD) response. This did solved my problem.
"Please ensure that you are gently touching the operational buttons on the camcorder rather than pressing them. Pressing too hard, or too rapidly in succession while waiting for a response, can desensitize the touch pad, requiring a reset of the camcorder.
If you find that the Mino has already frozen, we suggest resetting the camcorder.
To reset, simply take a pin and insert it into the reset hole within the camera’s tripod mount, wait five seconds before powering on, and then power on without touching any of the buttons on the back of the camcorder for an additional five seconds.
Please note that resetting the camcorder in this manner will not affect the videos resident on the camcorder; it will simply reset the screen and button sensitivity on the Mino.
Thank you,
Flip Video Support"
I hope this helps.
BTW my Mino HD has frozen twice now (I've had it for 2 hours total so far!) and the reset trick has fixed it both times. It seems to me the buttons are too sensitive or the computer program not the most stable. I hope this is the last of the problems!
Dec 14, 2008 | Pure Digital Flip Mino Digital Camera
Pure Digital Flip Mino Digital Camera Logo
1,860 people viewed this question
Top Pure Digital Cameras Experts
Ekse
Marvin
Marvin
Are you a Pure Digital Camera Expert? Answer questions, earn points and help others
