None of the settings work. It starts up but does nothing, but after a few mins both the rinse and spin light blink and the machine beeps. It all started after I forgot to close the lid during the rinse cycle for a heavy wash cycle load. The machine filled up with water then started spinning in one direction, but did not stop after I closed the lid, so I turned it off and on again, then it just would not do anything except those 2 blinking lights. I did drain all the water out and try to run the machine again, but same error code. Does anyone know how to fix this. Thank you
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names....
SOURCE: spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
SOURCE: Haier HLP21N washer won't fill. Water runs right through from the faucet to the drain hose.
Is the hose in the sink or on the floor? If in the sink, it sounds like the pump is running all the time. If the hose is too low, it maybe syphoning out the water as fast as its going in.
