Televison & Video Logo
Posted on Dec 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical bands 1-2 inches wide running through screen
Nonw
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Dec 10, 2014
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986939
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
2answers
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
7helpful
3answers
I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
2helpful
2answers
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc.com/">http://www.electron-age-technologies-llc.com
Grey transparent vertical band centre of screen
enter the bios nad set the keyboard option to unlock
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
