Necesito el driver para windows 7 con 64 bits
SOURCE: Won't print labels
Ended up being the heating settings - they were to low, so when I hit print...it would spit out a label but nothing would be on it.
Problem solved!
SOURCE: DATAMAX PRINTER
Hi
Its worth checking that you are using the latest drivers. You should be able to get these from the Datamax website. Also check the printer set up, gap sensor etc. Also check the media is loaded correctly. Hope this helps. Regards Stu www.labelzone.co.uk
SOURCE: Regarding Datamax E-4203 - Won't print
Check to see that the label sensor is over the gap in the label. It is just under the head on the right hand side.
You might also have the unit configured incorectly. If you go to the Datamax site, you can download the printer config program, It is easier to use than trying to push the buttons in the correct order to configure the printer.
Also use at least a 6" long label, and print the config file to see if you are set correctly for gap mode if using die cut stock.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
SOURCE: Where can I find the Datamax E-4203 Driver
I found the drive locally in one of the PCs and I run it on the PC with the problem.
Seg?n Windows 7 Centro de la Compatibilidad, impresora de Oki B4350 es compatible con Windows 7 versi?n x64. Si el asunto persiste, puede intentar de instalar al conductor de la Actualizaci?n de Windows para hacer clic aqu? :
http://catalog.update.microsoft.com/v7/site/Install.aspx?q=Oki B4350&referringpage=Search.aspx
Tambi?n, es recomendado contactando Oki para verificar directamente este asunto.
Adem?s, va por favor al Tablero de control -> Dispositivos e Impresoras -> el derecho hace clic en la impresora y entonces clic Localiza fallas para ver si el asunto puede ser resuelto.
Buenas Suerte,
Jose Diaz
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
