Symbol LS2208 Handheld Logo
a
attle2 Posted on Dec 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I have trouble with laser ls2208 it is PS2 connection but i have only USB on PC so i buy converter ps2 to usb but after connected scanner read product but not send text to pc .
I have this converter http://www.i-tec.cz/?t=3&v=33
Symbscanners
Level 2:
Scholar:
  • Expert 74 Answers
  • Posted on Dec 15, 2014
Symbscanners
Expert
Level 2:
Scholar:
Answers
74
Questions
0
Helped
107463
Points
150
You can try scanning the Keyboard Wedge host type barcode IBM AT Notebook then rebooting your PC. If this does not work you should order a CBA-U01-S07ZAR. This is the USB cable for use with the LS2208. Zebra Technologies support solution ADC-00217 addresses this type of issue. The article was written for connecting to a laptop, but your connection is similar if you do not have a keyboard attached to the cable. This link will take you to the solution which includes the IBM AT Notebook barcode. portal motorolasolutions com Print the article and scan the barcode then reboot your PC.
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Aug 06, 2007
SOURCE: LS2208 scanner unrecognized by my HP notebook
It is not likely VISTA will run your scanner software as it is very old. However you could check program compatibility mode and set it to run as Win 95/8 Check compatibility in Start/Programs/Accessories or go to my Computer Windows Help[ and type compatibility in the search field But I don't think you will get far.
A
Anonymous
  • Posted on Aug 11, 2008
SOURCE: LS2208-SR20007R-UR - USB connections - Red Laser Light going out
get the LS4208. they are much better
bluegreenash
Gareth Cockram
  • 661 Answers
  • Posted on Sep 30, 2008
SOURCE: LS2208 keyboard Wedge only works with PC keyboard connected
one of the settings in the code book is to emulate keyboard function. turn this on and you do not need to have the keyboard plugged in
Dave Busselle
  • 54 Answers
  • Posted on Feb 24, 2009
SOURCE: LS2208 works - Keyboard does not
Check that the wedge is good. It is basically a hybrid spltter that powers both the scanner and the keyboard.
USB keyboard?
If so, you may want to go direct to either a serial port or a USB direct connection
thesuperdude
Oscar Suarez
  • 97 Answers
  • Posted on Mar 26, 2009
SOURCE: Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
How to convert ps2 cunnector to USB connector in ncx 2000-xp
You can buy devices to convert USB to PS/2 like this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812150091
You might just be better off upgrading to a newer PC if you're able to do so. Good luck!
How do i connect a computer mouse to a samsung notebook
what's the mouse connector? is it PS2 (a round connector with pins on it)? or USB?
if it's USB,you can directly connect it to your notebook,if it's PS2,then you need to use a PS2-USB converter,it's cheap
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
2answers
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
9helpful
4answers
My dell sk8110 keyboard has a round purple connector plug that fit my old computer. My new computer has only USB ports. How can I connect my keyboard to the new computer?
http://www.microcenter.com/search/search_results.phtml?keyword=usb+adapter+ps%2F2&category=
The round purple connector is refered to as "PS/2" type connector. You can find an adapter that converts PS/2 to USB connector. The above link was just to show what I was refering to. Hope this helps.
Reading codebars
A solution to your problem would be to use usb cable to connect the scanner to the POS system. I have had a similar issue in the past where the IBM pos system did not like the cable that the customer had and we've got around this by using usb instead.
I hope this helps you although it may not be the kind of answer that you were looking for,
1helpful
USB keyboard?
2answers
PSC Duet RS232 and USB
you need to buy a USB to serial converter, you can pick these up of ebay for about $5 or from GPS shops for about $30
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
