Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an older Toshiba TF-501 fax machine that was given to me without a manual. I need to change the name in the programming to our company name. If someone knows where I can get a manual for this machine. Nothing on toshiba website.
Anonymous
Level 3:
President:
  • Master 1,126 Answers
  • Posted on Oct 23, 2009
Anonymous
Master
Level 3:
President:
Answers
1126
Questions
0
Helped
563437
Points
3418
Page 5-17 to set date and time, page 5-20 to program Name. Here is the link to Toshibe TF-501 in .pdf format and English.
http://209.167.114.38/dealers/opg/support/manuals/TF501.pdf
2helpful
MFC-8820D we have moved our office and have a new phone numder. How do we re program that number into our fax. Thanks matt
The following procedure will reprogram a new station (home fax number) for your machine. Thank you for using Fixya and please post back with any questions or to rate the answer provided.
Greg
  1. Press MENU 0,3
  2. Enter your new fax number (if the old still exists, move the cursor/arrow back ward to the first position to change the number displayed
  3. Press SET
  4. Enter telephone number (if it's the same as the fax number, enter the fax number again)
  5. Use the dial pad to enter your name (if your name still exists, leave it as it reads)
  6. Press SET
  7. Press STOP/EXIT
You will be given a choice to press 1 to continue with the change or 2 to exit without changes.
Press 1
The date and time will now appear and the change is complete
1helpful
Brother 4100 fax m\c
http://www.brothersupport.com/Facsimile/User/um_zlefax.pdf
Setting Station ID
You should store your name or (company name) and fax number to be printed
on all fax pages you send. The telephone number you enter will be printed only
on your cover pages and call back messages. (See Composing Electronic Cover
Page
, Page 6-6.)
1 Press Menu, 1, 3.
2 Enter your fax number (up to 20
digits), and then press Set. You must
enter a fax number to proceed.
3 Enter your telephone number (up) to
20 digits), and then press Set.
If your telephone number and fax
number are the same, enter the same
number again. The number appears
on Cover pages.
4 Use the dial pad to enter your name
(up to 20 characters), and then press
Set.
(See Entering Text.)
5 Press Stop/Exit.
The LCD returns to the date and time.
If your Station ID has already been programmed, the LCD prompts “1” to make
a change, or “2” to exit without changing.
I have a 2050P fax and it has not been receiving faxes for a week. Is could it just be programmed incorrectly?
Make sure the phone line is plugged in correctly...ie. into LINE not PHONE. Facsimile machines will recieve , normally, without "programming" for sending number or company name. You can also check to see if the line is active by pressing the on hook button for a dial tone.
HOW DO I CHANGE THE NAME(OF FAXER) ON OUTGOING FAXES?
Try MENU,*, w9 to get into Initial Programming then scroll to the "Name "you wish to change
OR try
Program, I(capital letter I ), ENTER to access initial programming then again scroll to nam you wish to change.
2answers
Changing a name
This model number appears to be a copier. Are you sure you have the right model?
http://safemanuals.com/zearch_634.php
Brother all in one MFC
According to the user manual, which can be obtained at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
if you don't have one handy, the steps to set your fax machine's number is on page 42. The steps to take are:
Setting the Station ID
You should store your name or company name and fax number so
they print on all fax pages you send.
1 Press Menu/Set, 0, 3.
(up to 20 digits).
Press Menu/Set.
3 Use the dial pad to enter your name (up to 20 characters).
(See Entering Text on page B-11).
Press Menu/Set.
4 Press Stop/Exit.
You cannot enter a hyphen in the fax number. To enter a space
press once between numbers.
If the Station ID has already been programmed, the LCD will ask
you to press 1 to make a change or 2 to exit without changing.
67helpful
8answers
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
2helpful
2answers
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Ricoh Aficio 5000L Fax Printer-Adding names to Group name
On every fax i've worked on, you cannot edit groups. You have to delete the group and start over.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
