I have to change a couple of the speed dials on Dad's phone and only managed to delete a couple I wanted to keep.
SOURCE: Programming GE corded speakerphone
I fixed this just now on my phone, while seeking a solution here.
- Do not do what you'd think... putting the phone and name info first. It looks like it will take this info but it won't. That's where the frustration comes from.
- Dial the PHONE# FIRST.
- THEN click STORE.
- Then click the location (A-C or 0-8... save 9 for 911 if you don't have a red emergency key).
- Then click STORE again.
- Then type in the phone number again... this works, though there's probably a way to do it w.o putting in the number twice... but since it works, don't sneer at the free advice :) LOL.
- Then click Store
- Then type in the NAME
- Then Store.
Done. Repeat for other names/numbers. Now that you have it down, you can figure out how to do this without entering the phone number twice... but since I have a busy day, I'm just doing it this way.
Best wishes!
SOURCE: How to enter phone numbers into the memory/speed dial?
The manual from the GE web site is here:
http://www.home-electronics.net/ge/pc/IB/29267GE3_IB.pdf
It's a pretty straightforward process, Pick up the handset press STORE a location (0-9) STORE dial the number STORE
With only 10 storable numbers it's pretty thin, but you also have the last 50 CID numbers to dial. If you live in an area with more than one local area code (overlays) and mixed 10 digit dialing, it looks like you may have some programming to do to make it dial CID numbers properly.
Carl
SOURCE: "Memory Full" message received by caller, although all messages are deleted.
Looking for a new answerling machine. The problem is evidently internal, in the electronics.
SOURCE: Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
SOURCE: GE 2-9439 Phone i need the manual to store numbers
1. Press the button you want to program
2. Press the Store button (red light will illuminate)
3. Enter the phone number
4. Press Store again (red light will flash)
5. Press the button you want to program (again)
