The red rubber on/off button fell off the bottom of one of my Sennheiser ew500 G2 mics. The mic works great, but we need to be able to turn the darn thing on and off without using a sharp object. Any solutions?
This is quite common with G2's, and really annoying!
If you are lucky, 50% of the time the red button is pushed inside the mic.
You need to remove the bottom section:
- open the battery compartment
- there should be 3 star-bit screws around the outside (remove)
- pull the bottom of the mic off
If the red button is not inside, they are available as a spare part from Sennheiser dealers.
Be carefull when putting the mic back together, it needs to line up correctly with the internal guides, forcing the base back on could damage the ribbon cable. when the line-up is correct it slides on very easily.
Best of luck.
PTB
You may purchase a spare Sennheiser red knob here:
http://artaudioparts.com/090362-red-rubber-power-button-on-off-for-sennheiser-skm-100-skm-300-skm-500-g2
