unfreeze it and start again
I had a freeze occur on an ipad air after trying a reset and the method for that was to hold down the button at the bottom of the screen and the button at the top side of the pad at the same time for around 20 seconds
the bottom button turns of the screen as does the side top button but when pressed together and held for a time it reboots the unit
if it is not the same the do what I did
go google on another computer and type in ---how to unfreeze 7" rca tablet --- and read forums and other sites that may give you a clue as to how to do it
Radio Shack has 8 air cleaner that also has a composite resolution in it that will unfreeze the buttonbe prepared to spend about 12 to 15 dollars for a 6 ounce can
Do a hard reset. Hold the power button down for twenty seconds. This is a hard reset if this does not solve the problem I recommend returning it as this is more than likely a manufacturer issue
Do you want to unfreeze your Android device?What is the make and model?I suggest you can approach Unlock-zone.com where they provide unfreeze code for Samsung mobile models.
