SOURCE: Bobcat Miller 225 won't start.
Check the oil safety switch maybe it is bad. It will stop running if low on Oil or wont start.
SOURCE: How do you drain the
Hi pplmelita,
If you don't have a petcock to turn the fuel off below the tank, I would disconnect the line at the filter and drain the gas out that way.
If you're wanting completely drain all old gas out, drain as above and then run until dry.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
SOURCE: how to separate the kohler engine from the
The shaft is tapered and will have a bolt in the center, loosen the bolt enough so you can tap on the end of the bolt. This should release the shaft, if not there should be 2 hole that you can thread a bolt into to push the connection apart.
SOURCE: Why is my bobcat 225 not welding hot enough?
If all your settings are correct and still not hot enough probably your fuse F1 is open and need to replace. Check page 42 of the owner's manual for instructions.http://www.millerwelds.com/om/o4434q_mil.pdf
Hope this fix your problem.
