I am transferring my digital tapes to DVD and at the top of the screen it is displaying the speed of the tape. I want to remove the display of words so that they are not recorded the entire time on m
I have tried going in to the display menu to remove it but it isn't working.
Try to remove power from the unit for a while and power back to see if that clears it or not----If a on screen counter display repair will usually cost too much or with this brand parts will not be available.
1) the vhs display can be defectivie a) for lack of voltage is missing b) display is defective. 2) you can buy a new ones converter. go to some appliances stores and search by new ones. 3) However you can go to the repair shop TV for fix it, and ask about the cost vs to buy a new ones converter. God bless you
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
Stop the tape.
Ensure the tape has been rewound to the beginning of the video recording.
Play the tape.
If the issue is not resolved, stop the tape and remove it from the camcorder.
Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
Reinsert the tape into the camcorder.
Play the tape.
Insert a different tape with video footage into the camcorder.
I am having the same problem with a Sony Digital 8, When I hit play I see blue screen buy when I press play and fast foward I see the same gray scan lines> Did you have a stuck tape or problems ejecting tape? I think it is more than cleaning the heads. When I try to record it indicates no tape in camera.
Unless both units has stated high speed transfer capabilities I think you have to do them one at a time and watch the entire video. There are some units that are one unit for vhs to dvd. Panasonic is known to have some units but you are going to probably have to hunt for one. It will clearly state that it transferred compressed or highspeed.
Atrk means that the unit is in auto-tracking mode and trying to lock in to the tape's recorded speed. This should go away after a short period of time once the tape has started.
It is unlikely that you will be able to solve this issue. This is due to the way a digital TV works.
The output from your VCR is an analogue signal - a constantly varying electrical signal carrying information about the picture. This is interspersed with a synchronisation signal that tells the TV where the start of each frame begins within the stream. With me so far?
When you fast-forward a tape, two things happen: the sync signals appear faster than expected and bars of static noise appear across the picture (I won't go into the technical details as to why!)
On an old analogue TV this isn't an issue - The way they work means that they will display some sort of picture. In other words, whatever signal is coming in (no matter how corrupted) it will show it on the screen.
Digital TVs are different. They have to read all the information for each frame and process it before it is displayed. When you fast-forward the tape (and the sync signals are at the wrong speed and interspersed with noise) a digital TV gets 'confused' - It cannot make sense of the signal, so ignores it, acting as if there is no signal at all (hence the blue screen).
Most VCRs are designed to retain enough of the signal that some sort of picture can be displayed while fast-forwarding. However, because you are recording in LP mode (which effectively halves the normal speed of the tape and also reduces the quality of the recording) there just isn't enough information in what is left for a digital TV to recognise as a 'proper' signal.
Your only option is to revert back to SP mode, or treat yourself to a new digital recorder :-)
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
