Televison & Video Logo
Evens Jean Posted on Dec 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW CAN I HAVE THE ACTIVATION CODE FOR A WESTINGHOUSE TV MODEL CW46T6DW
SO I NEED TO SET UP MY WESTINGHOUSE TV TO WATCH ALL MY LOCAL CHANNELS I CAN'T,CAUSE I HAVE TO ENTER AN ACTIVATION CODE WITCH I DON'T KNOW PLEASE I NEED SOMEBODY TO HELP THANK'S ADVANCE.
Ellen Tumey
Level 2:
  • Expert 176 Answers
  • Posted on Dec 19, 2014
Ellen Tumey
Expert
Level 2:
Answers
176
Questions
Helped
32162
Points
473
Try 0000. That I hear works.unless you're using with comcast or cable box, If that's the case let me know. I have a solution there too. Just alot to type right now..hope this helps.
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on Nov 30, 2008
SOURCE: can't get the channels to enter into the channel list
A lot of the " auto channel scan " etc. need a certain signal strength. you could have too meny tvs,equipment or anything connected to the "signal giver" that is sucking the signal strength.Not just turn off ALL connections to signal but disconnect the antenna 'input' to any equipment (sometimes people connect cable wires to radio receivers for stronger & better signals.)
You could have a open circuit to the input of the equipment in trouble.If you know how to get inside (with out killing yourself) connect an antenna directly to the end of the line of the intanna input INSIDE of the TV. if the signal comes in and the tv 'autoscans' and locks channels, then you have a open wire leading into the circuit.
p.s. BE CAREFUL!!, IF YOU don't know how or what you are doing.........DON'T DO DAT !! [that]
Anonymous
  • 5 Answers
  • Posted on Dec 30, 2008
SOURCE: can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Anonymous
  • 1077 Answers
  • Posted on May 28, 2009
SOURCE: I ACCIDENTLY SEEMED TO ENTER A CODE TO BLOCK CHANNELS IN MY TV SET AND NOW DO NOT REMEMBER WHAT THE CODE IS? IS THERE ANYWAY I CAN RESET?
To reset/clear the password for the LC-32SH12U TV, PRESS and hold both VOL-- on the TV and press 0 on the remote control simultaneously for a few seconds until (LOCKS) menu appears on the screen.
Now the old password was cleared. You can set the new password.
Anonymous
  • 1077 Answers
  • Posted on Jun 13, 2009
SOURCE: my tv has green, red, blue, and yellow halos on screen??
If you need a manual, you can use this link to get one.
http://www.retrevo.com/support/Hitachi-43UWX10B-TVs-manual/id/371dj799/t/2/
Chi Chu
  • 8457 Answers
  • Posted on Mar 22, 2010
SOURCE: when I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
I need an access code for my Westinghouse TV Model # CW40t2RW (SN = 7240V24903502)
The code is free, but you have to contact them by PHONE!
Why doesn't this Westinghouse web page provide an activation code when I provide the required information on my model and serial number?
A: Be sure to use the correct, complete serial number for your TV. You can find this at the product label. The serial number will always be 13 digits - all numbers except the fifth digit, which is a letter. If you continue to experience problems, contact Westinghouse customer care at 1-800-701-0680.Tuner Activation-FAQ - Westinghouse Electronicshttps://westinghouseelectronics.com > Support
Q: Why do I need to enter a tuner code for my television to receive over-the-air broadcasts? A: The access code input enables Westinghouse to accurately count ...
Westinghouse LD2480 no set up wizard?
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
I had cable took off and now i want just basic tv the regular channels abc, nbc, cbs and fox but when i try to scan the channels its asking me for a 5 digits access code for the westinghouse
you can go online and get the code. for some reason you have to go to westinghouse website and put in your model serial number abd it will give you a code allowing your tv to pick up local tv channels i dont know the reasong behind this
I need the turner activation code for my Westinghouse 26" TV that I just bougth today.
need the code for the cables channels the serial number is 6290Y10501455
TV LED 26' Westinghouse looking for activation code.
Hello Musiclab, to get the activation code you can do one of two things, call the toll free # 1-800-701-0680 or send me a quick email to [email protected], include the model # as well as the serial # and I will give you the activation code if you have not yet received one. Also once we are done please rate my answer.
Can this TV show local channels
Yes,Go to the tv menu,go to SETUP,go down to CH.press and select AIR.Will scan for over the AIR channels,u will get all the free air channels.After this u will get all the local channels,and other free air channels.
2answers
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
2helpful
Hi, I need the parental code to unblock
To solve this problem you will have to contact the manufacturer of the TV. Some TVs are made so that an omnipotence v-chip password can be used to unlock the set in cases where the password has been lost or forgotten. However, only the manufacturer would have access to this information. It isn't available in the public domain.
Also, if you never set the v-chip in the first place, your unit may need repair. Spontaneous activation of a v-chip lock is an indication that a problem has developed with the firmware of the device. The firmware is like the software that allows a piece of electronics to have menus, graphics, on screen displays, as well as the v-chip feature. Your unit may need a firmware upgrade.
But starting with a call to the manufacturer is the first step to fixing this particular issue.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
