The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
The fact that it takes the pictures ok confirms that it's not the ccd which has failed. A CCD problem would explain the
lines on your pictures and the lines on the LCD (since the CCD is used
to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used
in digital cameras. Some
symptoms of a defective CCD
include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card. When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Samsung themselves wouldn't normally
bother; a warranty claim usually means they chuck your camera away and
send you a replacement. If you're in the UK click here for details of how to proceed with Samsung.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Hu,
Just set your digicam to always flash whenever take photo rather than auto or red eye reduction modes. It will keep your flash when take photo.
If it is not work, then your camera has problem on board and need repair at dealer or local shop.
Regards
I'm working on the premise that you've deleted the photos from your camera memory or memory card.
If you have and used them since, its unlikely that you'll be able to retrieve them, you could have already over written them.
Its unlikely that you've deleted to your recycle bin, thats on your PC, usually already on your desktop. Camera's normally delete for good.
However, check your pc recycle bin, just double click onto it, it should be on your desk top. Once open you can choose to restore deleted files.
There are 2 file recovery programmes available for free from "filehippo.com" called "recuva" and "PC Inspector File Recovery 4.0". Download and install either of these onto your pc and recover from you camera memory to your pc (just create a folder on you desktop".
I don't know why I keep bothering to answer this question, as people tend to rate my answer as if I was responsible for the design decision, but I'll go for it again...
The ES55 was designed as a camera, storing images (and videos) to a memory card. It was not designed to stream live video to another device. If you want a webcam, you'll have to buy a webcam.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
I also have the same problem! I absolutely love this camera but suddenly out of the blue I have stripy lines on the screen that look like you are looking through a venetian blind. I have contacted Fuji but they say it will cost £99 to repair or have offered £50 discount on any other camera. I just want my F460 working ok. Please, please can anyone help us?
