Mitsubishi WD-52525 52" Rear Projection HDTV Logo
j
jeff mack Posted on Dec 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 35 shows DM fan failure, chassis fan.where is this located in tv . i heared there are 3 of them
Where is chassis fan located in tv
Mike LaPres
Level 3:
  • Mitsubishi Master 757 Answers
  • Posted on Dec 18, 2014
Mike LaPres
Mitsubishi Master
Level 3:
Answers
757
Questions
0
Helped
278398
Points
2002
Yes, there are three. The chassis fan, the exhaust fan and the fan for DMD.
The chassis fan is going to be mounted behind an intake air filter on the right side of the cabinet from the rear view. I am providing you the service manual.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&ved=0CFEQFjAH&url=http%3A%2F%2Fwww.audiolabga.com%2Fpdf%2FV26_Service_Manual.pdf&ei=QvWSVLjJJ8zIsAS2uYCQDQ&usg=AFQjCNF_iOS8W7HmGSRahWfnp68A4bOLCA&sig2=T8zMoyPLMAheVvkDZTFASg
4 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Feb 05, 2009
SOURCE: Where is the chassis fan location in a Mitsubishi wd 62525?
thats the fan thats directly mounted to the top of the Chassis's metal case
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Mar 15, 2009
SOURCE: 3-5 error code on mitsu wd-52725(chassis fan failure)
Check the power PWB pico fuse F9A09 and if thats good check the following capacitors all on the power pwb.
Power Supply
C9A52 1000uF 16V
C9A59 1000uF 16V
C9A61 1000uF 16V
C9A62 1000uF 16V
C9A39 2200uF 35V only some versions
have this cap.
C9A40 2200uF 35V
C9A37 3300uF 16V
C9A38 3300uF 16V
Anonymous
  • 556 Answers
  • Posted on Aug 18, 2009
SOURCE: Does not power up
Did you check the caps on the power board when you had it out?
Anonymous
  • 4889 Answers
  • Posted on Jul 02, 2011
SOURCE: Mitsubishi WD 52525 - Had
What is the color of the blinking timer light? Red/Yellow/ Green? I have a detailed error code chart without using the Device, Menu buttons so if you can provide this info I will see if the error code has been mentioned in the chart
Hello my name is Devin, I have a wd-65735 model and I just purchased it off of a friend and braught it home. He had told us from laying it on its side while bringing it home it said in the guide to let it...
Caveat: I am not a tech, I just read through the Mitsubishi service manual, and have worked on different model TV that I have owned (older model of this one) I am a little unclear on the second set of lights but I think the combination *may* indicate that the lamp fan is not starting (there are two fans though), if the blinking red is the status light. It is possible the connector for that got jostled during the trip, something fell into it from being on the side (wire or loose something) and is blocking it from spinning now, or a module unseated a bit,and is loose, or the lamp is no longer seated correctly (though the lamp light does not appear to be on) or none of these. :) These are just guesses.
Be careful if you open it up, due to potential for shock. Wear gloves, and power it down first (then unplug). Reseat any fan connectors.
Google: I used "wd-65735 status lights" to find a service pdf , it's for V39 chassis (several models)
From page 24 of Service Manual :
3. Error Code Operational Check Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Opera- tional Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The "TIMER LED" flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
  • ThenumberofflashesindicatesthevalueoftheMSD(tensdigit)oftheErrorCode.
  • Theflashingthenpausesforapproximately1/2second.
  • TheLEDthenflashesindicatingthevalueoftheLSD(onesdigit)oftheErrorCode.
  • The Error Code is repeated a total of 5 times. Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
Page 24
MODELS: WD-60735 / WD-60C8 / WD-65735 / WD-65736 / WD-65835 / WD-65C8 / WD-73735 / WD-73736 / WD-73835 / WD-73C8
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
ERROR CODES page25image3968
Code
Description
Most Likely Cause
12
No Error found
17
Communication loss, TV Micro - Engine (3.3V-ENG-SDA & SCL)
Engine Failure
18
Engine will not accept data (ASIC-READY signal from Engine is not detected).
Loss of 12V from PWB-POWER (Loose PE or PE2 connector); Bad Color Wheel (Loose J6 or J7 connector); Engine Failure
32
Lamp cover is open.
Lamp Cover Switch; Loose CD connector
34
Lamp turns Off while the TV is playing. Lamp failure
(Lamp Enable signal from engine is lost)
Lamp Cartridge Failure
36
Exhaust Fan failed.
Loose J4 connector
37
Engine (DMD) fan failed.
Loose J5 connector
38
Lamp temperature abnormally high.
Poor Air Circulation; Loose J3 connector
39
DMD temperature abnormally high.
41
Standby Supply Short is detected. (5VS or 3.3VS)
PWB-MAIN Failure
42
Sirocco fan failed (Lamp fan).
Loose J8 connector
44
Check for disconnected DVI cable between PWB-DM and Engine. (Engine pulls DVI pin 14 Low)
DVI Cable unplugged
48
PON-SHORT 3.3V switched supply short
PWB-MAIN Failure
57
Ballast communication problem (ballast to chassis)
Loss of 340V from PWB-POWER (PL or CJ1 connector); Loose FB or CJ3 connector; Ballast Failure
61
No LAMP-EN output from the engine to the ballast
66
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp) (Lamp-Enable goes to DM but not to Ballast)
Loose CJ4 connector;
No Lamp Inserted;
HV connection or lead wire to lamp; Lamp Cartridge Failure
Code 34(1) - Lamp Enable is generated to activate the Lamp
Code 57(2) - Lamp Enable is generated during P-ON sequence, but no Lamplit signal is received from the Ballast. Code61(3) -NoLampEnableisreceivedattheDMandBallast.
Code 66 (4) - Lamp enable is received at the DM but not at the Ballast.
4. Error Code Log
The Error Code Log - may be helpful to retrieve the code for an error the occurred in the past. To access the Error Code Log: Press <MENU> <3-5-6-4>
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
2helpful
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
2helpful
2answers
Bad Bulb?
the pins that protrude into the lamp compartment have a tendency to get out of alignment where the lamp will only make partial contact. It sounds like what youre describing.
Blank Screen
the code you said is not a code. What is the model # of your tv? Press and hold the "Device" and "Menu" for 5 seconds.......... 12 No error detected
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected Let me know what you come up with and your model # and I am sure I can help ya out as I have done alot of research on the Mitsubishi big screens lately as I just fixed all 3 of mine. Thanks Paul
3helpful
2answers
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
2helpful
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Mitsubishi WD62526 - Error/repair code
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Error code 1 2
I found this list of codes
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
