To leave voicemail message. spk *84 -following the prompts 200 # Service Code 32# Record message Put down Handset - pick up handset Dial 7901 to activate message I need the message to greet once Ive transferred the tel into night service. What do I do then?
SOURCE: need manual
If the VM is an in-skin for the NEC, you can't accomplish this thru System Admin via the telephone.
SOURCE: Voicemail Probelsm
I found the solution in some notes I have. Press Speaker, 43, 250, Speaker and the voicemail will activate. 250 being our central voicemailbox, you will need to know what your company's is.
SOURCE: Can't answer direct line calls
This sounds like a programming issue on this telephone. There are 2 areas in programming that would cause this. If you have recently had a technician out to do some programming then it is possible that he made a mistake and needs to be called back to correct his mistake.
SOURCE: How to switch between day and night mode?
from the operators phone hit feature key dial 80.it should toggle between day and night.
