I clean
If you take the front cover off (2 pins) take the inner cover off, check and clean sensors there, retry, if still fails disconnect laser, take inner upper cover off (this allow the rear connector of laser to removed) 2 screws and laser slides out, it does come apart, clean and be careful. the sensor that caused the error is ouside laser assy on rear right, a small board with 2 or 3 pin connector. -Carl
The LD Unit needs to be replaced. It cannot be cleaned.
