Question about Tannoy Audio Players & Recorders
Where can I buy new tweeters for Tannoy mercury v4 speakers?
  • 757 Answers
Try Parts Express website.
Posted on Dec 28, 2014
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: inverted(puhed in)tweeter
Hi George,
You may be able to pull them out using tape. That is sellotape then gently pull .They should pop out like
a dented car panel. My understanding is these domes really protect moving coil from dust so should not affect sound. Worst case swop the tweeter.
Ive just bought a pair of revolution 3 with same "fault" so I will let you know how I get on .I am in Electronics trade as profession. It may be possible to gently remove dome using a surgical blade then popping out and gluing on with PVA / Latex glue coloured with black ink if you dont like white appearance.
It is sometimes possible to pull out using fine sewing needle push in then gently pull out as if removing a spell from your finger.
Hope this helps
Posted on Mar 27, 2009
Anonymous
  • 23 Answers
SOURCE: My Tannoy Reveal 6D Monitors
I still suggest calling Tannoy, They are usually very reasonable and will give you a fair price to service a very good product
Posted on Apr 19, 2009
Anonymous
  • 30 Answers
SOURCE: can i get a tweeter for tannoy 607
ya.. u can.. you can check here, here.. Thnx
Posted on Aug 17, 2009
woodzowl307
  • 667 Answers
SOURCE: Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Posted on Feb 14, 2010
I work in a church that has 4 passive speakers across the room, 3 out of 4 of them sound super muffled and n one of them sound perfect Ive tried switching power amps, there is no processing help?
I would say from your description that the tweeters are blown.
Can you take the speaker that sounds good and swap it out with one that sounds bad. If you do that and the good one still sounds good. You have a tweeter problem. And they would need to be replaced.
Apr 01, 2015 | Tannoy Audio Players & Recorders
I just bought a pair of Tannoy Mercury V4 with a broken tweeter. Where do I find a new one?
check to see if you can find it on parts-express.com that's where I get all my speaker stuff
May 28, 2013 | Tannoy Audio Players & Recorders
Tannoy v1 reduced brightness from one tweeter, diagnose? replace? honestly unsure if broken tweeter is the duller one or the brighter one, help?
I assume you have more than one of these speakers. If so simply remove the tweeters from the two speakers and swap them around. If the other speaker acts up then, you know the tweeter is faulty. However if it stays on the same speaker it's the crossover that's the problem.
Jun 11, 2017 | Audio Players & Recorders
Recently lost both tweeters in my Reveal 6-D's.Got replacements and highs are back after an easy install.While testing the speakers I noticed a '' plop '' when the woofer travels extensively with heavier...
Hmm, what killed the tweeters? Over-exuberant operation? What's going on with your amp? Is it being pushed into stress or distortion? THAT will kill a speaker faster than clean high power.
Mar 11, 2011 | Tannoy Reveal 6D Speaker
Tannoy reveal speakers have lost treble
What you need to do is connect a 1.5 volt battery to the speaker(s) terminals for a split second. Put your ear to the tweeter at the same time (you might someone to help you do this). If the tweeter "pops" it works, if not you might have blown them. The best way would (to be certain) is to remove the tweeter from the crossover inside the unit.
Tweeters are the first thing to go when the speaker has been connected to an amp that is wrong for them or they have been run at high volume.
Apr 20, 2010 | Tannoy Reveal 6D Speaker
Feb 14, 2010 | Paradigm Monitor 9 Speaker
Can i get a tweeter for tannoy 607
Aug 17, 2009 | Tannoy (ST100) Speaker
Replacement tweeters for Eyris 1
If any new readers are seeking the same advice, then as at Feb 2016, replacements are available from Real Electronics in the UK, 08452 307 747 - this info from the service line at Tannoy. £63.21 + VAT + delivery. Part no 7900 0621
Much of the advice above is not applicable to the Eyris, folks seem to be posting generic solutions.
Unbolt the hex bolts at the rear of the tweeter assembly. With a screwdriver or similar, push the threaded rods forward to move the front portion of the tweeter housing free from the cabinet. The amount of flexibility in the cables may vary, and some users may have to remove the terminal block (hex bolts again) on the rear, and remove the acoustic wadding to gain flex in the cables.
There are three terminals on the tweeter, with push-fit spade connections. Green for Earth, red/black for signal. Disconnect these, pull tweeter forward, remove threaded rods.
Reassembly is the reversal of removal. Ensure all cables go in same places, etc. etc.
Mar 16, 2009 | Tannoy Eyris 1 Main / Stereo Speaker
My Tannoy Reveal 6D Monitors are only outputting sound from the tweeters. I'm looking for troubleshooting suggestions.
Dec 02, 2008 | Tannoy Reveal 6D Speaker
Inverted(puhed in)tweeter
Hi George,
Hope this helps
Nov 21, 2008 | Tannoy Mercury MX3-M System
281 people viewed this question
Top Tannoy Audio Players & Recorders Experts
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Trippy Tripp
Are you a Tannoy Audio Player and Recorder Expert? Answer questions, earn points and help others
