I remove the back cover
SOURCE: User Manual : Lavatherm tumble dryer T3
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: AEG lavatherm condensor dryer error
Make sure the water is completely out of the catch pan.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: AEG Electrolux Lavatherm 57800:
try cleaning the drum contact on the rear of the machine. It is a carbon brush that contacts the drum spindle. It can get covered in carbon from the brush.Remove the plastic cover containing the contact brush, clean out all carbon dust and lightly sand the drum spindle to remove any surface build-up and ensure a good electrical contact then reassemble.
SOURCE: AEG Lavatherm 57800 error E50
The problem is a worn motor carbon brush which connects power to the motor commutator. The carbon brushes are worn if the motor runs intermittently, if sparks are coming from the brushes, or if the motor doesn't run at all. This video should help you know more about motor carbon brushes and how they work. The video features a washing machine but the carbon brushes are basically the same.
