Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Reset Kindle Fire When it Won Turn on or Charge
Give enter to password, in blank, withoul inputting anything. Maybe it accepts it as password.
The other possiblity is that you've been pranked and someone defined a password
"Performing a hard reset on your Kindle Fire may resolve intermittent issues like a frozen screen, battery issues or trouble downloading content to your Kindle Fire. Allow your Kindle Fire to charge for approximately 30 minutes, then try the following steps. To perform a hard reset on your Kindle Fire, press and hold the power button for 20 seconds and then release. After the device has completely turned off, press the power button to restart your Kindle Fire. If your Kindle Fire is still unresponsive, try charging your Kindle Fire before trying to reset the device again." from here. Hope this helps, good luck.
To reset/reboot your Kindle Fire:
-With the Fire charged but unplugged from the charger, press and hold the power button for a full 20 seconds.
-When the Fire cycles off completely, press the power button once to turn it back on.
Are you sure you are using the latest version of Candy Crush Saga? Please download and install: Candy Crush Saga 1.12.0 Then install the latest version of Facebook on the Kindle Fire: Facebook 3.2.1 Try to link after you reinstall Facebook.
If I understand you correctly, you have a new Kindle Fire HD and would like to transfer the data from your old Kindle Fire to your new Kindle Fire HD. This is easy, follow these steps: Step 1: Connect the old Kindle to Wireless. Pull down the upper status bar, select More + and then select My Account on the old Kindle Step 2: Using the Old Kindle, select Deregister under My Account, let the task complete Step 3: When the old Kindle has Deregistered, then pickup the new Kindle. If you accidentally registered this Kindle Deregister it and then Factory Reset the device. Step 4: Now the old Kindle is Deregistered and the new Kindle is factory Fresh, let's begin the process. Step 5: On the new Kindle, let's reboot after Factory Resetting the device. When the device powers back up you should be presented with a login Window. Go ahead and register the device to the same account as the Old Kindle. The sync process should begin automaticlly, it can take up to one full day to sync all your content.
