I've tried resetting the beaters into the socket - they keep sliding back out. I've tried to get them to stay in by moving the lever back to the middle but as soon as I put the beaters in the lever slides to the right and the beaters fall out. The number one beater falls all the time but the number two will stay in more times than not.
SOURCE: KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set. Hard to find however.
SOURCE: Oster Regency kitchen center question
Look under the mixing head on the bowl side. There's a square "tab" that looks like the one on the back side of the machine. Pull it towards the bowl to release the mixer head from the base.
SOURCE: Sunbeam 2484 Beaters won't stay engaged.
In taking apart my same beater, I'm trying to figure out the alignment of the spring which provides the tension so that the beaters won't fall out. I'd assume that your spring has mis-aligned. You need to take it apart (3 Philips screws), and carefully pull the assembly apart. I'll bet your spring falls out like mine did. I'm trying to find a schematic from Sunbeam to see how the spring should align.
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well. The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure. I tried the cooking spray and it did nothing. But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater. I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes. When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer). It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft. But it did finally come off. After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off. So, I put a little bit of veg. oil on it, and it seems to be better. Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking. Best of luck!
