I have not removed the screws yet from the grill yet.
General Electric (GE) Profile refrigerators have a grille on the bottom of the front of the refrigerator. The grille allows air to be pulled from the kitchen into the lower compartment of the appliance by the condenser fan, which cools the refrigerator's compressor. At times this grille must be removed, such as when you are cleaning the compressor, emptying and cleaning the drain pan or adjusting the refrigerator's leveling legs to level the appliance. The grille is designed for easy removal: It is secured in place using only two screws
Phillips screwdriver
will be needed
SOURCE: Hotpoint refrigerator not cold
There is a defrost timer that initates defrost for 30mins every 8hours of compressor run time. Take off the thermostat knob and the freezer damper knob, remove light guard. To the right of the thermostat, is the timer advancement screw it is small,and it looks like a plastic cam not a screw. you put the flat blade of a screwdriver and rotate click by click till unit shuts off (you will hear louder click and fans and comp will shut off. Now its in defrost. Wait 5mins open freezer remove lower bin look at drain hole where frost buils you shoud see the heater glowing red melting the frost. If no red glow and no heat from panel. You must go further with the diagnosis.. A solved rating will keep this expert advice coming...........
SOURCE: freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
SOURCE: age of hotpoint refrigerator
There's a date code on the label with the model number. If you enter all the other info from that label, I think I can track down the year/month that it was made.
SOURCE: hotpoint refrigerator: model ctx18lyycrwh ::
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Testimonial: "i did find a verry tiny drain in freezer in a hard to get to place. is none for fridge. drain so small, it will probly freeze shut again. thanx "
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
Fan not working, fridge not cooling anymore, freezer seems ok
Hotpoint Fridge Freezer RFA52 BUT I DONT KNOW WHERE IS THE FAN CAN SOMEONE HELP ME TO TELL ME WHERE IS THE FAN IN MY FRIDGE SO I CAN DEFROSE IT.
PLESAE EMAIL ME ON: [email protected]
MANY THANKS
