Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
Check to make sure your set-top box is plugged in and turned on.
Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
I read about a similar problem and used the cords that came with the ps2, that ended up working. I also just bought a remote for the tv, so that fixed the channel problem.
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
blue screen indicares that there is a problem in blue cathode circuit.
please check
1 blue video output supply.
2 blue video ckt defective
3 signal from chroma ic to blue cathode missing.
4 loose connector
5 crt base loose.
6 chroma ic defective.
I think sound will be ok .
