LG WD-80100TP front loader. The drain pump is fine and the drain pipes are clear
Problem is with main board MOSFET ,FET or Transistor , that are not switching your drain pump at right time , if your'e pump is fine, , you should check drain pump separately by giving it separate supply. ( see its data sheet for power )
Testimonial: "Thank you Kalim. It was the drain pump. It tested ok but when it was taken out and power supplied seperately the motor didn't turn"
Pump filter is blocked. Clean the pump filter behind the front cover at the bottom right of the machine when it is empty.
Good Luck!
LG WD-80100TP WD-80100 TP manual, review
