PLS HELP IMMEDIATELY SERIOUS CASE I CAN'T USE MY TABLET NOW
Hi
I don't know what connectors you have on your tablet, but often there is a micro USB socket for connecting a lead from there to a standard USB socket on a computer. Some devices can also charge through this connection, so this is worth a try.
You may also try replacing the charger with a new one, in case yours has become faulty (you could check for a voltage at the plug for the tablet when the charger is plugged in by using a suitable multimeter on the right setting. Absence of voltage here would confirm a faulty charger.)
Otherwise, if the charger is OK and all the connections are firm and good, it may be necessary to replace the battery as rechargeable batteries do have a finite life.
Hope this is helpful, if so would you please register that with Fixya
Cheers
