I have placed the unit in charger the red light comes on for only a few seconds then fades away and remains off.have left unit in charger for around three hours but unit will not open ( no lights are on )
Sorry you are having an issue. Have you tried another charger? If so and it still doesn't work. CONTACT US . If you have proof of purchase that it was purchased new less than year ago then we'll replace it.
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In ______________________________________________________________________ •Headset Indicator Headset Status Red-----------------------------------------------Charging (battery level less than 50% charge) Yellow-------------------------------------------Charging (battery level more than 50% charge) Green--------------------------------------------Charging complete
---------------------------------------------------------------------- ====================================================================== ====================================================================== ====================================================================== ---------------------------------------------------------------------- With No Charger Plugged In __________________________
Headset Indicator Headset Status ______________________________________________________________________ Off ---------------------------------------------Power off Three blue flashes------------------------Powering on/off Steady blue --------------------------------Pairing/connect mode Rapid blue/purple flashes -------------Connection successful Quick blue flash --------------------------Incoming/outgoing call Slow blue pulse --------------------------Connected (on a call) Slow blue flash ---------------------------Standby (not on a call) Slow red flash ----------------------------Idle (not connected to phone) Slow purple pulse -----------------------Connected call muted Steady red ---------------------------------Attempting to connect Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on ----------------------------------------------------------------------
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Same problem for me: I start chargering (red light) and when I unplugged It don't power on anymore.
The solution for me was resetting the unit. Follow next steps:
-Start charging the ML10 (a red light will appear) -Press PowerButton and Volume(-) (a blue/right light will appear for less than a second). - Voila! It comes to life!
Normally if you have a VXi, B250-XT on its charger and you are seeing both a Green and Red light the headset is changin over from charging to fully charged. The headset is designed to be able to use while it is on the charger however once you place it on the charger you must turn it on to reconnect to your phone before you can do this. Put the headset on and press the Multifunction Button for 2 to 3 seconds, you should hear two rising tones and the headset should reconnect with your phone. Note* your phone may require you to accept the connection request. If the headset will not turn on either on or off the charger I recommend calling VXi at 800-742-8588 for warranty repair information. A headset that will not turn on indicates the unit is having an issue with one of its control circuits.
Dear Allen
Im strongly recommend you, buy a new original charger otherwise you can damage your headset.
The red light you saw probably because your charger is not compatible.
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results.
I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems.
Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked.
I hope to see similar results.
