Question about Ricoh Aficio 1515MF All-In-One Laser Printer
How do I over come a problem with my Ricoh Aficio 1515MF, whenever I try to power on the device the device display screen says Functional error SC:322. power off then on if problem persists call servi
I tried to check the board to see if there's any loose wires, but there's no any loose wire connected.
    New Friend:
  • 31 Answers
Forget the switch teory!!! this realy hapens in 22,35 and 45 cpm machines but not in this one. You have a faulty hexagonal motor or dirty mirrors in your laser unit. Wanna be sure? here`s the deal:
First, reset the code 322, doing this: Press in sucession, yellow button , 1, 0, 7 and keep pressed stop button (red) for 2/ 3 secs
it should appear service mode in the screen.
You dont neet to go any further, then press exit two times, switch off and on the machine. The code has been delected. Now, you should hear the laser motor start to spin. ( if you dont, the motor is Kaput, if it spins but the code show again, the beam is not beeing synchronized. (none of this operations will work if the switch is damaged, can they? come to me again if you need more info. Regards , aldo
Posted on Jan 06, 2015
    New Friend:
  • 16 Answers
Service manual & troubleshooting says this error related to laser unit but this is final solution. To my experience this error mostly because of Micro Door Switchs. Try it by changing Micro Door Switch. I am sure it will help you
Posted on Dec 25, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Ricoh Aficio 1515mf SC 121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Posted on Apr 30, 2009
Ickoajnc
OfficeServiceAjnc
  • 211 Answers
SOURCE: Ricoh Aficio MP 1600 Le error code sc 322 occured
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Posted on Jan 13, 2010
hinto
  • 13 Answers
SOURCE: service call sc:543 for Ricoh Aficio 1515mf
plz do like this after again it shwos same then need to replace parts thermister,and thermal fuses. press the yellow 107 red and hold the red for two mints it shows copy sp.......like switch off on
Posted on Sep 19, 2010
My copier Ricoh Aficio 1515mf is writing call for service
You must specify the error, displayed in lcd, something like Sc322 or sc 548, etc..
That will tell the technician witch part to look,laser, fusion,optics etc. Penzance are right! Go on, post it!
Feb 13, 2015 | Ricoh Aficio 1515MF Digital Copier 15cpm....
How do I fix a problem with my photocopier Ricoh Aficio 1515MF, whenever I try to copy it tells me to "Follow instructions in Right Cover to Remove"
Sounds like it thinks there is a jam. Check registeration sensor flag also exit sensor and duplex sensor. Could be dust or fuser sensor out of place or the duplex guide is broken
Dec 16, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
Necesito los drivers para la impresora Ricoh Aficio 1515MF
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x15_15f/x15_15fen.htm
Mar 05, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Error msg "sc552,Functional problem" on a Ricoh Afficio 1013F?
You either have a defective thermostat (thermistor) in your fuser, or a defective power supply. The error can only be reset by a tech in service mode after the problem is fixed
Jul 16, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Jun 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Service call sc:543 for Ricoh Aficio 1515mf
Mar 25, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Printing error log
reset the print jobs then check the printing refeperences.
Feb 08, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
112 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
