Question about Nextbook Premium 8 Se Android
My new nextbook shows wifi connected, but when i try to set up email, it can't open cnnection to srver. why. please help.
  • Paul Y.
    Paul Y. Aug 01, 2018
    Do not use manuals setups on e-mail unless you know what you're doing. Put the email on a normal setups.
  • 675 Answers
Are you able to connect other internet related applications through your WiFi.? If you have problem only in setting up your mail, either the receiving server may be temporarily down you may try setting up mail after sometime or your WiFi connection may be very slow. Check the connection speed from ScanMySpeed.com if it is slow, connect it with a better internet speed.
Posted on Dec 29, 2014
  • Nextbook Master
  • 5,748 Answers
Are you using an app to access your email?
Posted on Dec 26, 2014
2 Suggested Answers
6ya staff
SOURCE:
Gil Shultz
  • 3388 Answers
SOURCE: How do I set up an internet connection on my nextbook using an existing accoung?
Unless you have a network cable plugged in that is the only way it will work.
Posted on Dec 06, 2014
Can not get my new nextbook to connect to wifi
Go to settings
Wifi
Click on router name on wifi search
Click forget then the wifi search for your router name
Click on your router name type your password in and see if that works as you might have put your password incorrect the 1st time
Mar 18, 2018 | Nextbook Tablets & eReaders
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
My Nextbook 10.1 wont show the wifi ON/OFF switch, so I cant connect to the wifi
Do you mean a physical/hard, on-the-tablet WiFi ON/OFF switch, similar to the POWER ON/OFF switch ? I don't think any tablet or smartphone has that. You turn on/off WiFi with a "soft" switch from Settings-->Network (or WiFi). Hope this helps.
Jan 04, 2015 | Tablets & eReaders
I am trying to connect my tablet to my home network, but it isn't connecting... how do I fix this?
If your WiFi is ON then the station ID should be showing when you look for a wifi signal with your tablet.
You should configure the Access Point with a new password and then attempt to log in with that new password.
You may need to uninstall the driver for the wifi on your tablet and re-install it using a new driver.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
Nov 25, 2014 | Nextbook Next3 tablet
How do I connect my Nexbook 8 to the internet on my laptop
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
Sep 13, 2014 | Nextbook Premium 8 Se Android
Nextbook 8 cant get wifi to work now - worked before??
Hi there
You have checked that you are joined to the network via the router?
The laptop most certainly is.
Try disconnecting the router and turning the Nextbook off for a few seconds, connect the router on again and open Nextbook.
Join the network again and put the password in.
This way of connecting has worked for me. Hope it will for you.
May 06, 2014 | Nextbook Premium 8 Se Android
Nextbook Premium 8 Se Android Logo
242 people viewed this question
Top Nextbook Tablets & eReaders Experts
 Mike M
Mike M
Scott Fryer
john smith
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
