When it do not light up; either the lamp or its coverter is faulty. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Try to turn it on manually by the power switch - not by using the remote control. Try to unplug it for an hour or more to discharge the power system, then try again.
This is due to the safety features in the power supply section. If there is a problem somewhere in the monitor there will be a feedback provided to the power supply and the system shuts down to avoid any major damage.
you did not gave us the router version so look here for your password http://www.phenoelit-us.org/dpl/dpl.html scroll down to D_LINK and look for your version and your use and password.
If that didn't work, that means that someone has already changed the password.
Go to the router and reset it and the default password should be here http://www.phenoelit-us.org/dpl/dpl.html
Could have helped more if the router model was mentioned.
Sounds like the color wheel has shattered and the sensor is blocked by the peices. If the wheel was not blocked you would have a black and white picture.
You may have one of them set to the wrong DPL code. Most FRS radios have a channel number and another number that corresponds to a DPL code. Try looking in your owners manual for this feature it may be known under a different description as each company calls it different things. DPL, PL, private code, user code etc.
