LG Xenon GR500 Cell Phone Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Micro sd card mp4 video says " playback error"
I downloaded a mp4 video file on to my micro SD card but when I insert the card and try to play the video it says "playback error".
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1296
Points
I'm still trying to figure out the best quality of video the best format i found so far to work is MPEG4 of .3gp
Anonymous
Level 2:
Guru:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 163 Answers
  • Posted on Jul 06, 2009
Anonymous
Expert
Level 2:
Guru:
Mentor:
Answers
163
Questions
0
Helped
34741
Points
447
Sometimes the downlodad file format wont support the the file fornat of the phone .If u are using the micro sd card fo the first time the format the card . otherwise it may have this problem.
2answers
What format does sd card slot read
may not read unless formatted 1st.
Jan 12, 2018 • Cell Phones
3answers
How to copy file from DVD to SD ?
Put DVD in the drive on laptop/computer. Insert SD card in card reader in laptop/computer. Open "my computer" or whatever your operrating system calls it. Drag and drop contents of DVD onto SD card and wait until complete.
How to download video from youtube to micro sd
The data has to be compressed for the video to be loaded onto a micro sd card. Whatever media you have the sd card loaded in should automatically compress the file. Otherwise, you will need to convert the data to "flac". For example, a music file is found in MP3 or MP4 format. I have used a converter application for converting flac to MP3 when transferring from my sd card on my phone.
I am not sure if this will work the other way (compressing), but look up http://www.converterlite.com. It is free to download this. The site should give more detailed information for you.
No sound in video playback on laptop with sandisk micro sd card 2GB inserted
try downloading VLC player as this will play just about any file type that windows media player will not owing to copyright restrictions
1helpful
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
1helpful
2answers
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
D900 mp3 problem
Just try formatting the SD card. Hope it works fine.
Just connect the micro SD with computer.(You need SD adapter, SD card reader, and USB connection) Most computer will recognise the SD card automatically. Format the micro SD in the Window Explorer(or My Computer). Format menu can be found if you click right-button with cursor on the drive letter. After formatting, re-insert micro SD into your D900.
Some Korean experts says the problem might be caused by different file system (e.g. FAT, FAT32, etc) in each memory card. So they recommended not to share your memory card with different mobile phones as well as any electric devices (eg. MP3 player and digital camera).
6helpful
3answers
Unable to read DS micro SD card games
Have you installed Moonshell onto the micro-SD card? It has to be there to see the games. If you have Moonshell installed, you should be able to navigate to where you stored your files. Your adapter should have come with a CD with Moonshell on it or you can download a newer version on the internet.
2helpful
4answers
Power Acoustik PTID-4007
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
3answers
Samsung M310 Micro SD upload?
i do have micro sd and i am using a samsung unit. whe i want to grab a files from my computer. I am using a card reader/writer, insert my micro sd into the card reader, then connect it to the computer.
for playing/viewing just go to folder icon in your phone the choose memory card. thats is i can play/view my loaded files.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
