Serial #650100 1701285
SOURCE: need parts list for ELITE B40 KEURIG coffee maker
Should be listed in your manual. If you need parts check this out.
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
SOURCE: How do I clean my B60 Keurig of scale
Empty the water...
start with half distilled water... half white vinegar...
just run it all day... take a break and let the vinegar work... it will be heated up in the main tank... then pushed out to all hoses and sensors etc.etc...
enpty the container... wash it out... fill it with filtered or distilled water and run that until you no longer taste/smell the vinegar...
consider buying a brita pitcher and use that water for your Keurig... I do... and my unit goes for a long long time before it needs a vinegar washing...
P.S. dont use C.L.R. :(
It tastes bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Testimonial: "Thanks so much for the help. I already use Brita filtered water, so it's good to know I'm on the right track!"
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
