I asked this the other day but it showed up in the automotive section so I am reposting here in spas. Can anyone recommend any of the spa products like the scumbug? I have a fairly large Hot Springs spa with 5 reusable filters. I keep it clean but was considering adding one of the floating cleaning products I saw on a recent visit to the pool supply store. I see several alternatives on the market: scumbug, SPA-ABS, and ZorbO. These are all foam of some sort that is treated to make it absorb oil. Does anyone have experience with these and is one better than the others? Thanks
SOURCE: Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
SOURCE: pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
SOURCE: Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
