SOURCE: Admiral Heavy Duty 22lb. 2 speed motor going off balance
Had Same problem. Replaced The 6 retaining springs and snubber.
$15.00 worth of parts.
SOURCE: location of filter on maytag performa heavy duty washing machine
I have a similar problem---that is, the water flows very slowly into the tub ----I think tha something is "plugged-up"---
What to do??
Many thanks., Georgia
SOURCE: I have an admiral heavy duty super capacity plus 2
load lite, and if the problem still is there let run empty a couple of times, if there is still a problem it is off track and a professional needs to go inside of it you can do it yourself but not recommended so call a pro!!!
SOURCE: I want to open my
This unit has to be worked on from the back or under it. Most of the time that I had work on the pump for drain issues I would tilt it back against the wall and lay under it.
Here is a website (link below) that will show pictures of the break down to help you understand where the components are located. When you get on the website click the pictures on the left side bar for the different views.
I hope this helps.
GE Old Breakdown
