I try to put it on and off for few minute but still does not repord
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
FACTORY RESET
4. Release the "Reset" or up arrow button.
5. Allow the television to reset after the "Reset" message appears on the screen.
6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
7.Turn off the television and unplug the power cord from the electrical outlet.
8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
SOURCE: TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
SOURCE: SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
SOURCE: When I am trying to turn on the tv by remote or pushing the power buttton it goes to stand by mode
Solder bad connections vertical output IC......requires chassis
to be pulled....................T.
SOURCE: problem sony tv kv2197 go on standby
You may try resetting the TV to the original factory settings. If the issue persists then service will be required.
